Activity Forums Adobe After Effects vectors look pixelated
  • vectors look pixelated
    Posted by Wolfgang Amri on December 25, 2009 at 3:43 pm
    Hi all,
    I´m new here at creative cow (having only read so far and found great info) and also pretty new to After Effects.
    Guess what, I ran into a problem.
  • I am using vectors copied from illustrator onto a solid layer.
  • They work very well in 2D and also in 3D but only as long as the camera is in the same composition as the solids.
  • If I precompose the solids and make them 3D, they look pixelated when I make them larger or zoom in.
  • Checking the box continuously rasterize (as I´ve read here in the forums in a post from 2006) seems to convert the precomposed layers into 2D layers again, and the camera movement doesn´t affect them.
  • I´m on a mac using AE CS4, can anybody help???
    Thanks in advance and Merry Christmas!!!
Wolfgang Amri replied 16 years, 8 months ago 3 Members · 3 Replies
    • Tam Perl
      December 25, 2009 at 5:17 pm
      Wolfgang — I had the same problem. I suspect it’s something to do with the CS4 version of Illustrator, because I had no such problem with CS3 Illustrator files.
      In any event, my workaround is this: Open the Illustrator file in Photoshop. Since it’s a vector, it’ll scale up sharp. When you first open it in PSP, make sure that your size is the same (or better) than your largest final AE usage. Then disregard Illustrator, and use the PSD image. You can always scale down in AE if necessary.
      Tam
    • Bruce Wainer
      December 25, 2009 at 6:55 pm
      When using continuously rasterize on a comp, the switch actually becomes collapse transformations, meaning that After Effects treats the layer in the precomp as if they where in the outer comp. Therefore, for a layer to be 3D outside of the precomp, it has to be 3D inside of the precomp. Just open the precomp and set the vector layers to be 3D. Problem solved.
      Bruce Wainer
    • Wolfgang Amri
      January 3, 2010 at 9:08 am
      Hi you three!
      Thanks a lot for your help, I´ll get into this next week, being out of office at the moment. Just wanted to say thank you!!!
      All the best,
      Wolfgang
