Activity Forums Adobe Photoshop Vector smart to FCP
  • Vector smart to FCP
    Posted by Mel Hider on November 1, 2007 at 5:36 pm
    My knowledge of illustrator is limited to copying whatever is in there and placing it into photoshop where my knowledge is still rather restricted!
    So I have received a CS3 illustrator file and done my usual copy and paste (into Photoshop-CS3)- this time as a vector smart object. Once I have resized and prepped the image, I would usually export it as a tiff and then import that tiff into FCP 6. However, in this case, FCP doesn’t recognize the tiff.
    Also, I need to save transparency, so jpeg is a last resort.
    Is there a way to adapt the image in photoshop to make it readable for FCP?
    Mel
    Raymond Tuquero replied 18 years, 10 months ago 3 Members · 2 Replies
  • Richard Harrington
    November 2, 2007 at 1:44 pm
    Make sure you did not check the Transparency box in the save dialog if you added an alpha channel… and that you are not in CMYK mode
  • Raymond Tuquero
    November 5, 2007 at 9:04 pm
    Right … Video formats only read RGB. And FCP can read a layered photoshop image by the way. When you import a PSD file into FCP, it will create a Sequence with each layer seperated. You can then select the layer or layers you want to use in your edit. Good Luck with your projects.
    -Raymond-
