Activity Forums VEGAS Pro VASST Ultimate S Pro 4.2 for Vegas Pro 14.0 is now available @ vasstsoftware.com
  • VASST Ultimate S Pro 4.2 for Vegas Pro 14.0 is now available @ vasstsoftware.com
    Posted by John Rofrano on February 13, 2017 at 1:43 pm
    We completed the necessary updates for Ultimate S Pro 4 to work with Vegas Pro 14.0 this weekend.
    Existing customers can get the latest version from the download page on the vasstsoftware.com web site.
    This is a free update for existing customers so your existing 4.x license keys will continue to work. The install supports Vegas Pro 8.0 thru Vegas Pro 14.0 and will install one or both versions of Ultimate S Pro 4.1 and/or 4.2 depending on the version(s) of Vegas Pro that you have installed.
    There were no changes made to the 4.1 version but the 4.2 version was given a dark UI and physically expanded a bit to make some UI elements larger and make the interface more responsive to resizing. This means that Ultimate S Pro will look slightly different in Vegas Pro 14 than it does Vegas Pro 13. This is normal and only cosmetic. All of the functionality is the same in both versions but the version number will be different in Vegas Pro 14 from earlier versions of Vegas Pro.
    If you do not have Vegas Pro 14 there is no reason to download this update. It is the same exact code for Vegas Pro 13 and earlier versions.
    Enjoy,
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
    Steve Rhoden replied 9 years, 6 months ago 3 Members · 2 Replies
