Activity › Forums › VEGAS Pro › VASST: Ultimate S Lite for transition in videos?
  • VASST: Ultimate S Lite for transition in videos?
    Posted by Matt Long on April 16, 2011 at 4:26 pm
    Can I use Ultimate S Lite to add transitions to video clips? I plan on purchasing Ultimate S Lite for photo montage, but wanted to know how to use it for video clips as well during my trial.
    Also, will Ultimate S Lite work with NewBlueFx transitions?
    Thanks.
    John Rofrano replied 15 years, 5 months ago 2 Members · 1 Reply
  • John Rofrano
    April 16, 2011 at 6:19 pm
    [Matt Long] “Can I use Ultimate S Lite to add transitions to video clips? I plan on purchasing Ultimate S Lite for photo montage, but wanted to know how to use it for video clips as well during my trial.”
    It will create a montage with video as well but it will place the video the same as photos which is at the interval you specify. It will not lay out the video according to each files duration if that was what you were expecting.
    [Matt Long] “Also, will Ultimate S Lite work with NewBlueFx transitions?”
    Yes, it works with any transitions you have installed. When building transition lists for Ultimate S, it will show you all of the transitions install in Vegas Pro and you can assign any of them for use.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
