Activity Forums Apple Final Cut Pro Legacy varicam footage 60fps, how to import for slow mo?
  • varicam footage 60fps, how to import for slow mo?
    Posted by Jamie Nabers on February 3, 2007 at 1:35 pm
    i have footage shot at 60 fps with the varicam. I am going for the slow mo look. how do i get FCP to read this footage as slow mo? right now, while viewing on a monitor from playback from the tapes, it just looks like normal video…not 24p or slow mo.
    thanks,
    jamie
    Gary Adcock replied 19 years, 7 months ago 5 Members · 9 Replies
  • 9 Replies
  • Matt Small
    February 3, 2007 at 7:31 pm
    You need to capture over firewire after loading the DVCPRO HD – 720p60 Easy Setup. Then, you need to download the Panasonic Frame Rate Conversion tool from their website:
    https://www.panasonic.com/business/provideo/support/fcphd.asp
    Quit Final Cut, install the tool, launch Final Cut and select the captured footage in the browser window. Under Tools in the menu bar, choose DVCPRO HD Frame Rate Converter, and if you captured the clip correctly, it will recognize the flags and give you the options to convert the 720p60 to other frame rates.
    Matt Small
    Denver, CO
    “If it was easy, everyone would do it.”
  • Shane Ross
    February 3, 2007 at 7:51 pm
    Only the HVX can record and playback slow motion in camera.
    You need to use the converter, like Matt said. Here’s a tutorial.
    DVCPRO HD Frame Rate Converter:
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=8&page=https://www.creativecow.net/articles/ross_shane/dvpro_hd/index.html
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jamie Nabers
    February 4, 2007 at 1:03 am
    what if im bringing in my footage via HD-SDI?
    j
  • Shane Ross
    February 4, 2007 at 1:28 am
    [jamie] “what if im bringing in my footage via HD-SDI?”
    Dunno…never tried. Why are you bringing it in via HD SDI? What do you hope to gain? Capturig via firewire is very straightforward…
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    February 4, 2007 at 1:51 am
    An addendum about the downloading of the FRC from Panasonic. If you have FCP 5.1.2, you must use the FRC that’s on your FCP install disks as it’s a universal version.
    Jeremy
  • Jamie Nabers
    February 4, 2007 at 4:54 pm
    im using the kona 3 card. it has no firewire connection. HD-SDI is the only way to bring in HD footage through the kona card.
    j
  • Shane Ross
    February 4, 2007 at 4:58 pm
    Well then, there you go.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jamie Nabers
    February 4, 2007 at 6:29 pm
    so i guess i will just have to research a lil bit more…haha..
    thanks anyways,
    j
  • Gary Adcock
    February 5, 2007 at 3:50 pm
    [jamie] “im using the kona 3 card. it has no firewire connection. HD-SDI is the only way to bring in HD footage through the kona card.”
    FIrst
    make sure you have the most current version of the driver you can use.
    Use the 720p23.98 VARICAM setting (and this works for DVCPROHD, 8bit or 10bit captures done in this manner)
    Using that setting FCP should properly capture the Footage from the deck at the speed it was shot at, < 60fps = 2.5x slower playback) You need to set "in and out" points to make this work correctly - it does not work correctly using capture now. gary adcock Studio37 HD & Film Consultation Post and Production Workflows
