Activity › Forums › Apple Final Cut Pro Legacy › varicam downconvert to minidv
  • varicam downconvert to minidv
    Posted by Markfason on April 17, 2006 at 7:54 pm
    i’m starting a project next month that is going to be shot on a panasonic varicam using multiple frame rates.
    the client wants to downconvert to miniDV for the edit. if i’m digitizing the material with firewire what considerations should i have about the variable frame rates. is it possible to use the panasonic frc plug in once the footage has been downconverted? are there any other workflow obstacles i should anticipate?
    i’m a bit overwhelmed and any help would be appreciated.
    mark
    FinalCut 5.0.4
    Dual 2.7GHz PowerPC G5
    2GB DDR400 SDRAM (PC3200) – 4×512
    ATI Radeon 9650 w/256MB DDR SDRAM
    Segate 120GB external firewire drive
    David Battistella replied 20 years, 5 months ago 2 Members · 1 Reply
  • David Battistella
    April 17, 2006 at 9:57 pm
    The difference in size between varicam footage and DV is minimal
    Varicam@24fps = 5.5 mb/sec
    DV@24fps = 3.8 mb/sec
    Not worth doing the offline/online thing when cutting Varicam.
    720P HD is very easy to work with.
    David
    Peace and Love 🙂
