Activity Forums Adobe After Effects Expressions Variables using a dummy / null layer ???
  • Variables using a dummy / null layer ???
    Posted by Alex Dinnin on June 4, 2009 at 1:14 pm
    I’m not sure if I can do this.. but
    I have a layer with a drop shadow effect on it..
    there is an expression on opacity, angle and depth to slider controls in another comp..
    they look like this
    A = comp(“TVP_12_SEC_IDENT”).layer(“CHEESE_02_PC”)
    A.effect(“SHADOW_OPACITY”)(“Slider”)
    all the expressions are reference to “A” is there a way I can have a dummy expression window where I could put the layer name.. it would read like
    A= Dummy window;
    That way when I added it to a new layer.. I would only need to change one line instead of three.. possibly more !!!
    I hope this makes sense.. I appreciate I have waffled a bit..
    can this be done ??
    Alex
    Dan Ebberts
    replied 17 years, 3 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    June 4, 2009 at 1:22 pm
    It seems like you should be able to use a Layer Control (if the layer you want to reference is in the same comp as the control). Otherwise, you could stick the layer name in a text layer somewhere and reference it that way.
    Dan
  • Alex Dinnin
    June 4, 2009 at 1:49 pm
    Hey Dan,
    Unfortunately it’s referencing another comp…
    However I’m liking the idea of putting it into a text layer..
    so all I would do was pick whip the source text ????
    i’m rendering at the moment.. I’ll test it in a bit
    thanks for you great help.. your a legend !!!
    Alex
  • Dan Ebberts
    June 4, 2009 at 2:30 pm
    Say your text layer is named “layer name”. Then something like this should work:
    theName = thisComp.layer(“layer name”).text.sourceText.value;
    A = comp(“TVP_12_SEC_IDENT”).layer(theName);
    Dan
