Activity › Forums › Adobe After Effects Expressions › Variable or value expected, but found = expression disabled
  • Variable or value expected, but found = expression disabled
    Posted by Jayson Tin on July 24, 2008 at 5:08 pm
    Hi. I’m trying to create an effect where at a certain point in time, my displacement map starts to wiggle itself. So I made this expression on the ‘Max Horizontal Displacement’
    if(thisComp.layer(“Slider”).effect(“Slider Control”)(“Slider”))=1){wiggle(5,20)
    }else{
    wiggle(0,0)};
    However, I get the warining ‘Variable or value expected, but found = Expression disabled. Error occured
    at line 1.
    What is wrong with the code? Please help!
    Thanks 🙂
    Jayson Tin replied 18 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 24, 2008 at 5:20 pm
    You were very close. This should fix it:
    if(thisComp.layer(“Slider”).effect(“Slider Control”)(“Slider”)==1) wiggle(5,20) else wiggle(0,0);
    (Note the “==”)
    Dan
  • Jayson Tin
    July 24, 2008 at 5:55 pm
    Ahh, thank you so much 🙂
