Activity Forums Panasonic Cameras variable frame rate question
  • variable frame rate question
    Posted by B_ringuet on July 27, 2007 at 12:52 pm
    Hi, I’ve read the fine manual(s) and faqs and forum threads and just about anything one can get on the internet and still can’t get it right.
    Have: hvx200/fs-100/fcp 6
    Trying to do slo/fast mo. Understand it can either be done ‘in camera’ (vfr) or with fcp (frc). At least that’s my assumption this morning.
    None of my settings so far have worked so I won’t bother illustrating my profound stupidity.
    What I think I should be setting:
    hvx
    REC SETUP: 720/24P
    SCENE FILE: 48fps
    fs-100
    DVCPROHD REC
    QUICKTIME PN
    fcp 6
    DVCPRO HD – 720p24
    Barry Ringuet
    Barry Green replied 19 years, 1 month ago 2 Members · 1 Reply
  • Barry Green
    July 27, 2007 at 4:13 pm
    You can’t do it in-camera with the FS-100 (yet); perhaps a future firmware update will allow that.
    So yes, you’d set 720/24p mode and FILM CAM and set your frame rate to your chosen rate (in this case 48fps). Then, as I understand it, you’d run the Apple Frame Rate Converter utility to strip out the duplicate frames and leave you with a 24fps file with (approximately) 2:1 slow motion.
    With that said, you’ll have to ask one of the Apple experts here for more info on the process of using the FRC; I’m just pointing out that yes, that’s the workflow that you’re going to have to follow to get this to work.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
