Activity › Forums › Apple Final Cut Pro Legacy › Vanishing Sequences
Vanishing Sequences
Posted by Scott Levin on June 3, 2007 at 1:47 pmHi,
Twice now, entire edits have disappeared. The browser and viewer remain, but the timeline and canvas are gone. There have not been any leads to discover the source of this problem. Has this happened to anyone else? Thanks, ScottScott Levin replied 19 years, 3 months ago 4 Members · 5 Replies -
Jerry Hofmann
June 3, 2007 at 9:58 pmIf you close the sequence in the Timeline Window both it and the Canvas will go away… so double click a sequence in your Browser to re open it, and both windows will come back!
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Neil Ryan
June 3, 2007 at 10:29 pm[Jerry Hofmann] “If you close the sequence in the Timeline Window both it and the Canvas will go away”
requires the disclaimer, Jerry: ‘when only one sequence is open’
does it not?Neil.
Neil Ryan
Post Production
The Pod Multimedia
http://www.the-pod.com.au
Scott Levin
June 4, 2007 at 12:43 pmHi, Thank you, very much. I apologize for not giving more info. I had tried what you suggested before and a timeline came back with a couple of random clips on it. I save often, so that was not it. Is it possible that it’s a software issue?
Best, Scott -
Citykitty
June 6, 2007 at 1:19 amI have a similar issue, but when I go double click on the sequence it won’t open. And I can’t open a new sequence either. Any clues?
Scott Levin
June 6, 2007 at 10:30 pmHi,
I don’t have any clues right now, but I will certainly pass on anything that comes my way.
Thanks, Scott
