Activity › Forums › Adobe After Effects Expressions › values between markers
  • values between markers
    Posted by Nino Vrana on February 10, 2015 at 6:20 pm
    hi,
    this is my problem. I have placed a set amount of markers on a null object which i have linked via Dan Ebbert’s expression (see below) to a slide control. At each marker the value increases by 1 (in whole numbers) So far so good. What I am trying to achieve though is to have an expression in place that will give me all the values between the whole numbers too, i.e. 1,1 1,2 1,3 etc… is there a way? any help is much appreciated.
    thanks
    Current expression:
    n = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time){
    n–;
    n = 0;
    n--;
    Nino Vrana replied 11 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 10, 2015 at 6:54 pm
    It sounds like you’re looking for something like this:
    n = 0;
    if (marker.key(n).time > time) n--;
    if (n > 0 && n < marker.numKeys)
    linear(time,marker.key(n).time,marker.key(n+1).time,n,n+1)
    else
    n
    Dan
  • Nino Vrana
    February 10, 2015 at 9:14 pm
    thank you so much Dan, this is exactly what I was after. Your help is much appreciated.
    Thanks.
