Activity Forums Adobe After Effects Expressions ValueAtTime on Scale property
  • ValueAtTime on Scale property
    Posted by Jamil Yamani on January 21, 2012 at 11:18 am
    HI all
    I have been using Dan Ebberts code modified for Colour and various other things with great success.
    I have tried applying it to a Scale property and it did not work. The scale value once the expression is turned on remains at 100%, 100% despite the keyframes I have applied.
    Thanks in advance
    Jamil
    delay = 6;
    d = delay*thisComp.frameDuration*(index - 1);
    thisComp.layer(1).transform.scale.valueAtTime(time - d)
    The Electric Canvas
    Large Format Projection Specialists
    Sydney, Australia
    Jamil Yamani replied 14 years, 8 months ago 3 Members · 3 Replies
  • Ben G unguren
    January 21, 2012 at 3:18 pm
    Scale is multi-dimensional, so you need to produce 2 or 3 numbers (3 if the 3D switch is enabled) instead of 1.
    It’s easy enough to do; just assign a variable to the last line:
    a = thisComp.layer(1).transform.scale.valueAtTime(time - d)
    Then make your answer apply to X and Y with the following:
    [a,a]
    Or, if it’s 3D:
    [a,a,a]
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Dan Ebberts
    January 21, 2012 at 4:39 pm
    Your expression should work fine. My guess is that maybe layer 1 is not the one with the keyframes.
    Dan
  • Jamil Yamani
    January 21, 2012 at 6:31 pm
    you are very right, its all working now.
    thanks very much to all of you
    jamil
    The Electric Canvas
    Sydney, Australia
