Activity Forums Adobe After Effects Expressions Value out of a “while loop” decreases when it should not.
  • Value out of a “while loop” decreases when it should not.
    Posted by Alberto Brancolini on December 1, 2011 at 5:01 pm
    Hallo everyone.
    Here I’ve got a weird behavior -to me, at least- by an expression and I’d like to understand where’s the mistake I made.
    I wanted to have an esteem of the overall distance of a cycling course.
    After drawing a mask all along the roads, I pasted it to a null’s position and turned the comp’s framerate to 50 for a higher accuracy.
    Then I took Dan Ebbert’s (thank you, your website saves my life almost daily) expression for accumulating random values and I fitted it to my need. At the end, I divided for the maps scale.
    Now the fun part: the value sometimes decreases, expecially when the path bends.
    My knowledge is that a curve may not be represented correctly, but it’s still a vector between two points.
    So, can you tell me where’s my mistake?
    Thank you.
    j = 0; //counter
    dist = 0; //distance
    p1 = transform.position.valueAtTime(time);
    p0 = transform.position.valueAtTime(time-thisComp.frameDuration);
    while (j<time) {
    dist += length(p1-p0);
    j += thisComp.frameDuration;
    dist/comp("scala").layer("Null 4").effect("fattoreConv")("Slider")/10;
    Alberto Brancolini replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
