Activity › Forums › VEGAS Pro › V13.463 won’t load
  • V13.463 won’t load
    Posted by Rob Lindsay on January 28, 2017 at 11:18 pm
    Hello
    Just upgraded to a Dell running W10 on a quad core 6700 CPU w/ 16 gigs ram and a 3 gig GPU.
    Since installing, Vegas has been relatively stable, freezing after being on for over 24 hrs. Today, i added 2 jpegs, one a 4 mg file, to the timeline. Vegas froze — except for the audio, which kept running! Using the task manager, i killed Vegas bu it has frozen during start up ever since. i have deleted the 2 jpegs from the folder where i imported them from but no luck, Vegas still won’t open.
    So frustrating! I had better luck with my old V11 on my Vista system!
    Any help in getting it back up is appreciated!
    Rob Lindsay
    Nashville filmmaker
    Rob Lindsay replied 9 years, 8 months ago 2 Members · 2 Replies
  • Graham Bernard
    January 29, 2017 at 5:22 am
    [Rob Lindsay] “Any help in getting it back up is appreciated!”
    I would rename the troubled VEG as a Test, something like TEST.veg and attempt to open it.
    Do you know the size of the JPEGs? Something is choking Vegas from opening. If the project Opens without the JPEGs then we have reasonable proof that the stills are responsible. The test I would try, with the TEST.veg would be to temporarily remove the JPEGs from the TEST.veg by locating them in Windows Explorer and renaming them. If the TEST.veg opens but complains that it can’t find the JPEGs then have VP ignore them, allow VP to open and when open get busy with the rest of the project to truly confirm that there isn’t anything choking VP.
    This type of CSI/Forensic process can being very helpful in understanding just what and when VP chokes.
    * Grazie
  • Rob Lindsay
    January 30, 2017 at 3:53 am
    Thanks, Graham. I had done all that. i think it was a 4 mg jpeg that crashed the app, I reduced it to around 750kb in PS and it worked.
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
