Activity Forums Media 100 V13.0.4 Audio Missing.
  • V13.0.4 Audio Missing.
    Posted by Gregg Michaels on August 19, 2009 at 3:02 pm
    Similar to the problem discussed about V1, I’m having the problem of missing audio on import, but not exactly. The quicktime file was created in fcp 6.0.6. (Apple ProRes422/16bit Integer-Big Endian L/R Stereo) Video imports fine, but the audio at first appeared to be stripped out. What I discovered was that the end of the audio track has slipped to the beginning of the clip. Any help on this is appreciated.
    Mac Pro/Kona3-6.0.3/MacOS-10.5.7/QT-7.6.2/M100-13.0.4
    Gregg Michaels replied 17 years ago 2 Members · 4 Replies
  • Wickham Strub
    August 19, 2009 at 9:38 pm
    Hey Gregg,
    See David’s post above. Most likely your problem too.
  • Gregg Michaels
    August 19, 2009 at 9:47 pm
    Hi Wick. Actually, I did try his workaround, but I still have the same problem. When I drag the clip from the bin to the program, I see that the audio tracks are cut shorter than the video. In fact, I’d say that the audio tracks are only 25% of the total length of the clip. In addition, the audio has slipped, so that the end of the audio track is at the beginning of the clip.
    GM
  • Wickham Strub
    August 20, 2009 at 3:47 pm
    Grrrr…
    Looks like we’re gonna need a sample file from you also as it seems to be a different problem.
    Let me know how you can get it to us. YouSendIt seems to be working out nicely for most people.
    ~Wick
  • Gregg Michaels
    August 23, 2009 at 12:46 pm
    Hi Wick. Sorry, I’ve been out of touch until today. I’ll have to post the file to our website, and I’ll email a link to support. It sounds like the same problem that’s listed as a fix in Suite V1.01.
    GM
