V13 can’t get “arm for record” to light
Posted by Rob Lindsay on January 13, 2018 at 12:55 amHere is a SS of my Audio Devices card:
I don’t know if that helps but I’ve changed inputs front to back, changed Windows 10 to Stereo Mix per an earlier post here, but i’m stuck, and i am trying to record a VO with an external mic.
All help is appreciated!
Vegas 13.453
Dell Windows 10
Intel6700 quad CPU
16 Gigs RAM
3 Gig GPURob Lindsay replied 8 years, 8 months ago 2 Members · 19 Replies -
Graham Bernard
January 13, 2018 at 6:19 am[Rob Lindsay] “All help is appreciated!”
I’ll try.
Although I’m running W7 not W10 it’s has to be similar, here’s my VP13 and VP15 recording onto Timeline. Make sure you have the Mic Icons lit on the Track Header!:
VP13
VP15
Two questions:
1] What is that ASIO Realtek Device for and I’m asking ‘cos VP and ASIO don’t play nicely, but as it is there why wouldn’t you use it? My external Presonus AudioBox uses ASIO and it works:
2] What are the selections you’ve made in Audio Devices? Here’s mine for recording:
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Rob Lindsay
January 13, 2018 at 6:31 amThanks for your response, Graham.
1. I don’t see any mic icon on my track header or yours either. Confused!
2. Here’s a view of what I do see:
3.Here is the device control for W10
4 I dont know what the Asio is. I thought it just came with the computer.
Rob
Vegas 13.453
Dell Windows 10
Intel6700 quad CPU
16 Gigs RAM
3 Gig GPU -
Graham Bernard
January 13, 2018 at 6:42 amAh-hah!
I went back and compared both of our Direct Sound Surround Mapper. Do you spot the difference?:
Yours:
And now mine:
You’re missing that “Primary Sound Capture Drive” option, which I believe has to be part of the selection you can make from my previous thread.
* Grazie
Graham Bernard
January 13, 2018 at 6:44 amLol, and yes it had been lit, but in making the screen grab and stopping recording it had switched off! – Don’t be confused.
* Grazie
Graham Bernard
January 13, 2018 at 6:59 amHere’s mine showing that the INPUT is Live for DSSM:
I believe, I can’t see all your Track Header, but here’s yours greyed-out, I think (?):
Bottom line here, that Primary Driver option needs to be activated – yeah?
* Grazie
Rob Lindsay
January 13, 2018 at 7:03 amThank you, Graham — the arm button is lit and i can see the db monitor respond when I speak into the mic during a recording. But I dont see any wave form on the track as it is recording and there is no audio in playback :(.
Getting closer tho!
Any more suggestions?
Vegas 13.453
Dell Windows 10
Intel6700 quad CPU
16 Gigs RAM
3 Gig GPU -
Graham Bernard
January 13, 2018 at 7:09 am[Rob Lindsay] “Getting closer tho!”Yeah . . . . How did you activate that Driver?
OK, let me see your Track Header. Expand its width.
* Grazie
Graham Bernard
January 13, 2018 at 7:18 am -
Graham Bernard
January 13, 2018 at 9:11 amWell? Silence? I can’t hear you . . . ?
* Grazie
Rob Lindsay
January 13, 2018 at 4:11 pmSorry, Graham, i went to bed. i wasn’t focussing any more. here is the current state of recording
Thank you — i am now recording to the track! The only issue I have now is that the level is very low, even tho as you can see, the pot is pushed up. Any thoughts?
Vegas 13.453
Dell Windows 10
Intel6700 quad CPU
16 Gigs RAM
3 Gig GPU
