Activity Forums Maxon Cinema 4D UV unwrap with seam (like blender)
  • UV unwrap with seam (like blender)
    Posted by Din Iulian silviu on March 25, 2019 at 6:54 pm
    Hello folks!
    It is possible to unwrap objects in cinema 4d by settings seams (like blender > mark seam)
    I tried in many ways, watching at tutorials, reading from forums, but I have not found a solution…
    Here are images:
    Din Iulian silviu replied 7 years, 4 months ago 3 Members · 4 Replies
  • Brian Jones
    March 25, 2019 at 7:51 pm
    not real experienced with UV mapping but with a simple cube without a bottom and the corner edges selected like your object, I get what I think you want by selecting Shrink in Projection then going to UV relax and Cut Selected Edges checked and Pin Border Points and Pin to Neighbors unchecked
  • Emir Bojorquez
    March 26, 2019 at 2:15 am
    -Select The edges that you wanna use.
    -Go to Select >> Set Selection (To create a Selection Tag)
    -Drag and drop that selection tag inside the Relax UV >> Cut selected Edges and tun it On (check box).
    -Go to Projection >> Flat.
    -Go back to Relax UV >> Apply.
    Hope that helps.
    Good Luck
    Imagination is the best tool…
  • Brian Jones
    March 26, 2019 at 2:39 am
    ahh nice, rotated 45 compared to my test but no distortion, thanks Emir
  • Din Iulian silviu
    March 26, 2019 at 7:30 am
    Thank you Emir Bojorquez !!!
    Your answer really helps me!
