Activity Forums Maxon Cinema 4D UV texture maps – pixel perfect
  • UV texture maps – pixel perfect
    Posted by Kit Carson on September 12, 2019 at 1:25 pm
    How can i make this uv map of this partial cube to fit pixel perfectly side by side into this 960 x 480 texture area?
    Sam Treadway replied 6 years, 11 months ago 2 Members · 1 Reply
  • Sam Treadway
    September 13, 2019 at 1:10 am
    While in UV Polygon edit mode, select all the UV polygons on the object.
    In the UV mapping dialog window > Projection tab: Click on “Cubic 2”
    Then on the Tansform tab: Set the Scale X and Y attributes to 2 and 4
