Activity Forums Maxon Cinema 4D UV problem – Wall With Window
  • UV problem – Wall With Window
    Posted by Mohannad Talafeeh on September 12, 2012 at 5:23 am
    Hi guys , I’m trying to uv this simple model(attachd) which a window within a wall , but I cant get a decent uv map especially because of the seam between the wall and windows rim , what I want is a one seamles uv for both with no streching so I dont get any strange results , I’v tried many ways but non of them seem to work (please check them ),of course I could just use the projections options without the need to the uv edit but I have a specific texture that need to be applied , so in other way what is the best way to uv that model ..
    Adam Trachtenberg replied 13 years, 11 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    September 12, 2012 at 5:02 pm
    Couldn’t you just use flat projction for a wall? btw, there’s no attachment.
