Activity Forums Maxon Cinema 4D UV map cube with rounded edges
  • Adam Trachtenberg
    January 5, 2014 at 5:35 pm
    It depends on your priorities for the object. You have to balance your need/desire to minimize texture distortion vs. your need/desire to reduce the number of seams. Unfortunately you can’t minimize both at the same time.
