Activity Forums Maxon Cinema 4D uv map as vector file?
  • uv map as vector file?
    Posted by Ronny Traufeller on May 10, 2012 at 10:08 am
    hey, i a actually
    doin a job with a uv map
    wraped in after effects
    with a plugin.
    uv map + textur = 3d(sort of)
    then you get bad anti alising on the edges because
    a uv map uses colors to define the positions. so
    if ou feather corners you would change positions….
    maybe there is a way to have a vector file,
    maybe i think the wrong direction …
    thanks,
    ROnny
    traufeller.de
    Ronny Traufeller replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
