Activity › Forums › Apple Final Cut Pro Legacy › Using XDCam HD with Final Cut Pro
Posted by New User on April 2, 2007 at 3:18 pmCan Final Cut Pro use XDCam HD footage when recorded at HQ level?
Chris Sinclair replied 17 years, 8 months ago 6 Members · 7 Replies -
Mark Maness
April 2, 2007 at 3:33 pmSure!
I do it all of the time. But you really need to make sure that you have Sony’s Transfer Software 1.1 and using at least FCP 5.1.2.
If you haven any other questions concerning this, feel free to contact me and I will try to help you in any way possible. By the way, my company has been using XDCAM HD since May 2006 and XDCAM products since April of 2005.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com -
Shawn Bockoven
April 2, 2007 at 4:29 pmUsing XDCAM SD and HD at our station. I love the import function.
Shawn Bockoven
METV -
Andy Mees
April 3, 2007 at 5:35 amyes indeed, however if there is a purchasing decision involved, and if you are platform agnostic, then I would recommend waiting a couple of weeks and seeing what is the status of the Apple/Sony XDCAM integration post NAB.
as it stands, there are other NLE’s that have better XDCAM HD integration than FCP is “currently” offering -
Stuart Simpson
April 3, 2007 at 12:55 pmAre you also mastering final programmes back to XDCAM HD? If so are you doing it through HD SDI or as a firewire file copy, or over gigabit?
-Simmie
2 G5 – Kona LH
3 G4s – Cinewave
1 xbox360, 1 PSP, 1 PS2 & a Gamecube
https://www.speak.co.uk -
New User
April 3, 2007 at 1:50 pmI will be mastering final programmes back to XDCAM HD, and would like to know which is the best way: HD SDI or firewire file copy?
Mark Maness
April 4, 2007 at 3:17 pmIf you are editing in XDCAM HD, then export firewire using Sony’s Transfer software.
If you are editing using DVCProHD (like most of us do), use the Print to Video command and use HD-SDI.
Wayne Carey
Schazam Productions
Chris Sinclair
January 13, 2009 at 4:59 amI’ve got the PDW-700 and PDW-HD1500 deck, and we can get stuff off the DL discs, but how can we copy disc footage to another disc, and/or output an edited sequence back to disc all on a Mac running all the latest (FCP 5.0.6 and OSX 10.5.6).
Chris.
