Activity › Forums › Adobe Premiere Pro › using widescreen footage in a 4:3 project
  • using widescreen footage in a 4:3 project
    Posted by Eva Gur on January 5, 2010 at 2:17 pm
    Im editting a showreel which contains both widescreen (16:9) footage and regular (4:3) footage. most of the footage is 4:3 so i wish that the project will be 4:3.
    i have captured the 16:9 footage while using 16:9 settings.
    but when i import the 16:9 clip into my 4:3 project it appears to be streched.
    what i want is to work in a 4:3 project, and have the 16:9 footags appear with a letterbox.
    how can i do this?
    Eva Gur replied 16 years, 8 months ago 2 Members · 2 Replies
  • Jeff Pulera
    January 5, 2010 at 4:46 pm
    Hi Eva,
    When you import a 16:9 clip into your 4:3 project bin, right-click the clip and choose “Interpret Footage” and choose the appropriate pixel aspect from the list to get the correct look.
    In the event that you would want to eliminate the black bars on any of these clips, use Adobe Motion > Scale to enlarge the clip until it fills the screen. Some image will be cropped from the right and left, but you can adjust left or right using Motion to crop as needed.
    Jeff Pulera
    Safe Harbor Computers
  • Eva Gur
    January 9, 2010 at 1:26 pm
    Thank you
