Activity › Forums › Maxon Cinema 4D › Using Voronoi Fracture on Text
  • Using Voronoi Fracture on Text
    Posted by Tony Lengyel on December 13, 2016 at 3:43 pm
    I am pretty sure I am on the right path here as to figuring out why this happens so let me explain first.
    I use Mo-Text to create text, apply fillet-caps etc… then make object editable then connect & delete to drop it in a Voronoi fracture.
    It works like it’s supposed to but the text faces seem to get “pillow” effect on them. So I am thinking that it has to do with the segments or the way the object is connected together. When I use optimize and close holes on voronoi it makes the “pillow” effect on the faces. I want to keep them looking as original until fracture.
    I know it’s probably something simple like segments or a tick box but everything I try i.e. bumping up segments etc still produce this undesired effect.
    I can post pictures if need be, but I think I explained it enough for someone to help.
    Thanks.
    Adam Trachtenberg replied 9 years, 9 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    December 14, 2016 at 12:10 am
    Not sure what you mean by pillow effect. Can you post a scene, or at least a screen shot?
