Activity Forums Adobe Audition Using volume envelopes with stereo files
  • Using volume envelopes with stereo files
    Posted by Nancy Burnett on September 29, 2011 at 3:03 pm
    When I use volume envelopes with stereo files for music under voiceover, I am bringing the envelope to the middle of the bottom channel. If I don’t do this, the bottom channel is still full volume.
    But this means I have eliminated all audio from the top channel, and created a mono waveform. Is there any way to reduce the volume in each channel so I can maintain a stereo waveform?
    Nancy
    Nancy Burnett replied 14 years, 11 months ago 2 Members · 2 Replies
  • Steven Talley
    October 13, 2011 at 1:23 pm
    Sounds like you are accessing the fader control (left to right).
  • Nancy Burnett
    October 13, 2011 at 3:55 pm
    Thanks for your suggestion, but it’s not the fader control. I am adjusting the volume control (the green line at the top of the track), but in order to reduce the level of both channels in a stereo recording, I need to bring the volume control all the way down through the top channel to a position in the middle of the bottom channel. It seems to me that cuts out the volume of the top channel.
