Mike Kujbida
October 30, 2013 at 5:00 pmRick, I don’t know what else to suggest. I just tried it on my work machine (running Pro 10) and it works as expected for me.
Rick Hughes
October 31, 2013 at 10:38 amIt does ‘come back from ‘off line’ after a few minutes, maybe it is just as it is processing large file.
Back to an earlier point when the ‘edited file’ appears on time line …should there be a label ?
i.e. I could have 2 very similar audio tracks, how can I tell which is which … in your post above it neatly shows the label 00011 and 00011 Take 7
Can you turn on a label ?Concerned I may not have correct one active at any particular time.
Mike Kujbida
October 31, 2013 at 11:25 am[Rick Hughes] “ck to an earlier point when the ‘edited file’ appears on time line …should there be a label ?
i.e. I could have 2 very similar audio tracks, how can I tell which is which”
To see what I had on my screenshots, use View > Active Take Information.
Ctrl+shift+i is the shortcut key. -
Rick Hughes
October 31, 2013 at 11:44 amI’m not following … if I go you your post above
I can’t find any ‘view take active information’ option
If I do ctl_shift+i I get a lower window open of forum code ….
Noreen Degale
November 1, 2013 at 11:09 pmOne of the TV stations in Grenada has started adding ASL interpreting to one news cast a week. As this newscast is a summary of the week’s news the videos used in the newscast do not have an interpreter making them useless for the deaf and only allowing them to get information from a short lead in from the news announcer.
The technical team doesn’t know how to get the interpreter on the video. Can you give me some advice so I can pass it on. Many thanks
