Activity Forums VEGAS Pro Using Visual Studio 2005 for Vegas scripts
  • Using Visual Studio 2005 for Vegas scripts
    Posted by Apostleofzion on July 17, 2007 at 10:11 am
    hi ,
    VS 2005 Express edition for C# is available as a free download from microsoft. This particualrly targets .Net 2.0 framework. Since Vegas 7 script uses c# language.It should be really useful and fast to use VS 2005 c# Express.
    When creating a windows form application ,we get 4 files. Form1.cs(to code action for form buttons&events) ,Form1.Designer.cs(pre built code for the form creation) , Program.cs(to start the program),AssemblyInfo.cd (for assembly ).
    In Vegas scripting we have the Clas EntryPoint with the public function FromVegas (). I don’t know where to include this function in those files to create a dll for the Sony Vegas 7.
    Any help would be appreciated.
    Apostleofzion replied 19 years, 1 month ago 2 Members · 4 Replies
  • Edward Troxel
    July 17, 2007 at 1:01 pm
    Take a look at Vol 4 #3 of my newsletters. It should give you enough info on where to put that. If not, let me know and I’ll help you out.
    Edward Troxel
    JETDV Scripts
  • Apostleofzion
    July 19, 2007 at 6:08 am
    hi edward ,
    In that newsletter you have mentioned a file called Interop.VegasCOM.DLL which would be found in the Vegas 6.0 folder. But I’m using Vegas 7 , i couldn’t find that file in Vegas 7 folder .Although i was able to add reference for the Sony.Vegas.dll in VS 2005 C# through the project properties.
    And you have given the link for the project file . I assume that project was done in VS “2003” .But i when i opened in VS 2005 , it converted the project . and gave two missing refernces out which the one mentioned in the top is not found. the other one ” Sony.Vegas.dll “was found and i added it .
    so i deleted the other reference and it works.
    Thanks for the article edward.Hope this clarifies any doubts regarding using VS2005 for vegas.
  • Edward Troxel
    July 19, 2007 at 1:24 pm
    [apostleofzion] “you have mentioned a file called Interop.VegasCOM.DLL which would be found in the Vegas 6.0 folder. But I’m using Vegas 7 , i couldn’t find that file in Vegas 7 folder .”
    You are correct. That file is not necessary to add at this time.
    [apostleofzion] “so i deleted the other reference and it works.”
    Glad to hear you got it working.
    [apostleofzion] “Hope this clarifies any doubts regarding using VS2005 for vegas.”
    Vegas 5 used VS2003. Vegas 6 did as well. With Vegas 7, you can, technically, use either. To have a single version for versions 6 and 7, I stuck with VS2003. If you’re only going to be working in Vegas 7 or newer, VS2005 is what you need.
    Edward Troxel
    JETDV Scripts
  • Apostleofzion
    July 20, 2007 at 5:21 am
    thanks for the clarification and guidance 🙂
