Activity Forums VEGAS Pro Using Velocity Envelope, Loosing luminosity
  • Using Velocity Envelope, Loosing luminosity
    Posted by Francois Pénzes on April 9, 2017 at 3:36 pm
    Hello everyone
    First time using this feature in Vegas and I am completely at a loss… I am applying the Velocity Envelope to a 45 sec. clip with a white background in increments of 250% each time after render. (I have to narrow it down to 6-7 seconds)
    Each time I apply the envelope, I lose about 7% luminosity. Red channel stays the same, green drops a bit and blue even more.
    Project is an Sony .MXF file, 50Mbps (CBR), 59.940 fps prog.
    I can’t figure it out.
    Any suggestions ? Explanation ?
    Cheers !
    PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    \’\’When the cutting stops, the editing begins…\’\’
    Francois Pénzes replied 9 years, 4 months ago 2 Members · 5 Replies
  • Paul Berk
    April 10, 2017 at 2:22 am
    First, which version of Vegas are you using?
    Second, are you talking about “velocity”or “composite level”? Why would Velocity (speed) reduce your luminosity?
  • Francois Pénzes
    April 11, 2017 at 12:37 am
    Hi Paul
    I’m using V.14 and Velocity only.
    That’s the thing, it shouldn’t affect the luminosity as far as I understand it. There are no other effects applied, not even Event Pan/Crop. All files were shot with the same camera, same controlled lighting, on the same morning, inside.
    I’m at a loss…
    Cheers !
  • Paul Berk
    April 11, 2017 at 5:05 am
    Three questions.
    Are you measuring the loss of luminosity after the render in the rendered file?
    How exactly are you measuring the luminosity at about a 7% drop each time?
    Can you repeat this behavior with different media and different render settings?
  • Francois Pénzes
    April 11, 2017 at 10:23 am
    Hi Paul
    [Paul Berk] “Are you measuring the loss of luminosity after the render in the rendered file?”
    Yes, after I import it back to Vegas
    [Paul Berk] “How exactly are you measuring the luminosity at about a 7% drop each time?”
    With the Vegas included Waveform (luminance)
    [Paul Berk] “Can you repeat this behavior with different media and different render settings?”
    I will do some testing and get back to you.
    Many thanks for your time !
    Cheers !
  • Francois Pénzes
    April 13, 2017 at 12:52 am
    Hi Paul
    Tried it with other rendering formats and could not reproduce the problem. I was hoping to keep all my files in the same format as the original files.
    If you ever come up with even something of an explanation, let me know.
    Cheers ! …and thank you !
