Activity Forums VEGAS Pro Using Vegas with Norton running
  • Using Vegas with Norton running
    Posted by Mark Krueger on March 21, 2011 at 10:53 am
    I read somewhere that you should disable your computer virus protection software prior to working with Sony Vegas. I have worked with Vegas both with the protection software active and with it disabled and really did not notice any difference in processing or anything else. I am using Norton. Is it really necessary to disable Norton prior to working with Vegas? Is there any relationship to crashing and working while protection software is active?
    Kevin Mccarthy replied 15 years, 5 months ago 5 Members · 4 Replies
  • John Rofrano
    March 21, 2011 at 12:40 pm
    If you are not having problems then there is no need to disable it. Norton is a particularly heavy weight program that tends to take over your computer. I would never recommend that anyone use it but that’s your choice. Depending on how aggressively some of this software is configured, it could cause problems with programs like NLE’s that require a lot of files be open at once. Norton is extremely aggressive and has been known to slow down system performance dramatically.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Frank Stevn
    March 21, 2011 at 1:46 pm
    I use Microsoft Security Essencials. It is lightweight, efficient and free. But the best anti virus is: Don’t use your editing PC for navigating the Internet!
  • Stephen Mann
    March 22, 2011 at 3:35 am
    MSE has been so reliable here for the past few months that it’s hard to believe that it’s from Microsoft.
    It’s fast, it’s small and it’s no resource hog like Norton.
    That’s two things that Microsoft has done well (MSE and Win 7).
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Kevin Mccarthy
    March 22, 2011 at 10:00 am
    FYI, if you chose to remove Norton from your computer by using the control panel’s delete program app, you need to know that simply removing the program does not remove all of the Norton JUNK. You shoulg go to McAfee’s sight and download the Norton removal tool to get rid of all of the Norton files.
