Activity Forums VEGAS Pro using ultimate S with vegas native multicam
  • using ultimate S with vegas native multicam
    Posted by Wayne Grauel on November 19, 2009 at 2:39 am
    i have a multicam timeline that i just finished. it looks like its a cuts only option with vegas.
    will ultimate S add transitions to my cuts ( overlap them by equal amounts and leave the cut location intact?..
    did a little experimenting .. good thing i saved my work!… it wasn’t pretty.
    basically i want to select either the entire multicam timeline ( one track in vegas pro8 or a starting point or a range to have cuts overlap for transitions.
    Wayne
    John Rofrano replied 16 years, 6 months ago 3 Members · 6 Replies
  • Wayne Grauel
    November 19, 2009 at 3:37 am
    GOT IT used Excalibur… the other one will take some getting used to so i need to try it b4 the trial runs out..
  • John Rofrano
    November 19, 2009 at 2:01 pm
    What tool in Ultimate S Pro did you use? You should be using the Create New Transition tool on the Editing Tools tab.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Edward Troxel
    November 19, 2009 at 3:38 pm
    Glad to hear Excalibur could help you out. Just to be fair to Vegas, though, if you hold down the CTRL key when you add the camera switch, it will create a dissolve instead of a cut.
    Edward Troxel
    JETDV Scripts
  • Wayne Grauel
    November 19, 2009 at 6:44 pm
    Thanks Ed… I swear a lot of software programs rely on mental telepathy when you look at their native help files
  • Wayne Grauel
    November 19, 2009 at 9:00 pm
    John, If i’m not mistaken i tried that.. but it shrunk my timeline down.. since it is synced to music.. that wont fly.. so i told Excalibur to make each clip X seconds longer — and that gave me automatic crossfades
  • John Rofrano
    November 19, 2009 at 10:50 pm
    Understood. Vegas Pro Production Assistant has a more sophisticated crossfade tool. It gives you an option to actually extend the clips in place and also has additional options for what to do if there is no media left to extend. Ultimate S Pro does not have this.
    ~jr
