Activity › Forums › Apple Final Cut Pro Legacy › Using Toast to make a DVD Pal movie.
  • Using Toast to make a DVD Pal movie.
    Posted by Graham Scholes on October 27, 2005 at 2:40 pm
    I have been having trouble trying to make a PAL formated movie using Toast.
    My movie documentary is 64 minutes long and when in FCP I export using “Using Quicktime Conversion”
    The movie Settings I define are as follows……
    Video …. is checked.
    Compression: Video
    Quality: Best
    Frame rate: 29.97 – ( (I have tried a file without a frame rate).
    Sound ….is checked.
    Format: Uncompressed
    Sample rate: 44.1 kHz
    Sample size: 16
    Channels: 2
    Prepare for Internet Streaming…. is checked. (I have tried a file with out this checked).
    When I drop the resulting Quicktime file into Toast with the Options set at PAL and click to proceed with burning a DVD I get a window that comes up saying, –
    “The video standard has been changed to NTSC”
    Can someone advise what I am doing wrong and how to prevent Toast from reverting back to NTSC when I try to burn a PAL DVD disc.
    Graham Scholes
    http://www.woodblock.info
    G5 2 Mhz OS X 2.9. FCP HD 4.5
    Graham/Sidney BC
    An Island in the Pacific
    Wilhelm Beck replied 20 years, 11 months ago 3 Members · 3 Replies
  • Sean Oneil
    October 27, 2005 at 6:24 pm
    You are exporting an NTSC Quicktime. PAL is 25fps and has a different resolution. Toast is not going to do a PAL conversion for you.
    Use Final Cut and convert the sequence to PAL, using a plug-in like Natress. Then export a PAL Quicktime Movie.
  • Graham Scholes
    October 27, 2005 at 7:27 pm
    Thanks Sean for the feedback regarding the plug-in Natress. Will work with this.
    Regards
    Graham
    Graham/Sidney BC
  • Wilhelm Beck
    October 27, 2005 at 8:58 pm
    If your footage is 29.97 (NTSC) and you want to make a PAL movie I would look no further than compressor.
    In my experience compressor is rather slow but the results are good.
    An Apple a day keeps the doctor away!
