Activity Forums Apple Final Cut Pro Legacy Using Titles From AE in FCP as a Clean Overlay
  • Using Titles From AE in FCP as a Clean Overlay
    Posted by Brett Putman on May 6, 2010 at 6:13 pm
    I have made some simple name titles for a for a corporate video in After Effects.
    I then exported them via the Render Queue as using the “best” settings to maintain the highest possible quality.
    When I drop these titles into Final Cut Pro the background is black (not transparent as I would like), so I have to mess with the composite modes in FCP to get the titles to appear over my footage, but when I do that, the end result is not accurate to the original compiste from After Effects and the colors shift and things just get generally out of whack.
    The fact that we have to use different composite modes in FCP works for the time being for me, but the final version of this project should be accurate to what is being exported from AE.
    Alex Tanin replied 16 years, 4 months ago 4 Members · 4 Replies
  • David Roth weiss
    May 6, 2010 at 6:25 pm
    You have to export using the Animation codec – Millions of colors+, which carries an alpha channel.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Brett Putman
    May 6, 2010 at 6:50 pm
    ya, I did that and still no go.
  • William Jon miller
    May 6, 2010 at 9:07 pm
    Brett I’ll tell you what has happened to me and that is I set up the titles with a background to see how it looks and I’ve forgotten to turn the eyeball off before rendering. Even if you render with an alpha if you have a background then the background shows.
    Jon Miller
    404-216-6021
    wjonm2002@yahoo.com
    https://jonmiller.tv
  • Alex Tanin
    May 6, 2010 at 11:22 pm
    Editei um vídeo que tem gcs passando na parte inferior do video (grawl), mais quando passo para dvd (dvdstudio pro e outros), o gc grawlfica batendo como se fosse interpolação de field????, tentei upper field (nativo da captura (hvx170),loewr field sem resultado algum,gostaria de saber se alguém tem uma solução para esse meu problema..
    Desde já agradeço e aguardo resposta.
    Alex Tanin
