Activity › Forums › Adobe After Effects Expressions › using ‘time’ to change only y-position
  • Filip Vandueren
    March 18, 2007 at 7:18 pm
    try this:
    speed=1;
    position + [0,time]*speed
    position has 2 values, or 3 if it’s a 3D-layer:
    speed=1;
    position + [0,time,0]*speed
  • Mike Clasby
    March 18, 2007 at 7:21 pm
    I think AE assume the x position is being considered if you don’t specify. Since position in terms of x and y is”
    [ position[0], position[1] ]
    try this:
    [position[0], position[1] + time]
    You probably already know, but if you want the movement to be faster, multiply the time by a number, times 8 in the example below:
    [position[0], position[1] + time*8]
