Activity Forums Apple Final Cut Pro Using the Title tab in the Inspector to animate titles without using keyframes.
  • Using the Title tab in the Inspector to animate titles without using keyframes.
    Posted by Phil Snyder on November 7, 2014 at 4:14 pm
    On a scene that ran 4:04 seconds, I set the Out Tracking to 100%. The letters in the title spread appropriately and smoothly at the end of the scene. However, on a shorter clip (3:04), the letters
    jumped abruptly from the original positions to the opened-up position. I even tried key framing the tracking and got still no better results. Is this because the clip was a second shorter forcing the tracking to react faster. I even tried the “Decelerate” feature to no avail. Plus, I trashed Preferences to correct any weird FCP X behavior.
    Finally, I gave up, set all the Out features (Scale, Tracking, Opacity) to the Default settings and, for some strange reason, got horizontally revolving letters at the end of the clip. A nice effect, but not one that I asked for.
    Is this some kind of a bug or am I doing something wrong?
    Thanks.
    Phil Snyder replied 11 years, 10 months ago 2 Members · 2 Replies
  • Jeff Kirkland
    November 8, 2014 at 9:55 pm
    You’d probably have to say which title effect you were using before we can give you any sort of answer. At a guess though, the animated title probably has a minimum duration it can animate over and you’ve made it too short.
    Open the title in Motion and take a look. You can probably modify it and make a shorter version if needed.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Phil Snyder
    November 9, 2014 at 12:04 am
    I was using Out Tracking to animate the end position of the title and pulled down the Opacity to 0%.
