Activity › Forums › Adobe After Effects Expressions › Using the Numbers effect to translate Heart Rate data into a readout??
  • Using the Numbers effect to translate Heart Rate data into a readout??
    Posted by Saxon Rix on January 27, 2015 at 12:01 am
    Hi guys I was recommended to come over to the expressions side of the AE forums as the problem I have may be able to be fixed by an expression.
    I am doing a project where I’m making use of a heart rate monitor. I am able to extract the heart rate data (which is recorded once every second such as: 99, 101, 100, 100, 100, 101, 102, 102, 107, 113 etc). The data was recorded for around 31 minutes, which gave me 1910 of those numbers.
    I am wanting to use this data to make a number readout in After Effects, but I’m not sure how to add or use the data I have in order to make it accurately follow the data.
    So it has to read from the list of 1910 numbers, and display each number for 1 second each.
    Any ideas if this is possible guys?
    Saxon Rix replied 11 years, 8 months ago 2 Members · 11 Replies
  • 11 Replies
  • Dan Ebberts
    January 27, 2015 at 12:29 am
    What does the data look like?
  • Saxon Rix
    January 27, 2015 at 12:34 am
    It is literally just a list of numbers with commas separating them like such:
    171,171,171,171,170,170,170,170,170,170,170,170,170,170,170,170,170,171,171,171,171,171,171,171,171,170,170,170,170,159,159,159,159,159,159,159,159,148,148,148,148,148,148,148,0,0,175,174,173,173,173,173,173,174,174,174,174,174,174,174,174,174,174,174,174,174,174,174,175,175,175,175,175,176,176,176,176,176,176,177,177,177,177,177,177,177,177,177,178,178,177,177,177,177,176,176,175,174,172,171,170,170,170,170,170,171,171,171,172,172,172,172,172,172,172,172,173,173,173,173,173, etc.
  • Dan Ebberts
    January 27, 2015 at 12:50 am
    If you can edit your text file so that the line starts like this:
    myArray = [171,171,171,171,170,170,
    and ends like this:
    172,173,173,173,173,173];
    Then an expression like this should work:
    myPath = “c:/test/test.txt”;
    $.evalFile(myPath);
    idx = Math.min(Math.max(Math.floor(time – inPoint),0),myArray.length-1);
    myArray[idx]
    You’ll need to edit myPath to point to your text file.
    Dan
  • Saxon Rix
    January 27, 2015 at 12:59 am
    Thanks Dan I am just about to try this out. Do I apply this expression to the numbers effect ‘value’ setting?
  • Dan Ebberts
    January 27, 2015 at 1:05 am
    That should work. I tested it by applying it to the Source Text property of a text layer.
    Dan
  • Saxon Rix
    January 27, 2015 at 1:13 am
    It worked! Thank you so much :). Sooo glad I don’t have to do it all manually lol.
    Thanks again Dan, you’re awesome!
  • Saxon Rix
    January 27, 2015 at 1:20 am
    Sorry to bother you with another question Dan, but is there a way to make the numbers change color once they get to a certain number threshold?
    Like this
    90 – 120 = green
    121 – 150 = orange
    151 – 180 = red
  • Dan Ebberts
    January 27, 2015 at 1:29 am
    With the numbers effect? Something like this for Fill Color should work:
    val = effect(“Numbers”)(“Value/Offset/Random Max”);
    if (val < 121)
    [0,1,0,1]
    else if (val < 151)
    [1,.5,0,1]
    else
    [1,0,0,1]
    Dan
  • Saxon Rix
    January 27, 2015 at 1:36 am
    That does work great! Is there a way to link it to ‘hue/saturation’ effect so that the color gradually changes from green to yellow to orange to red as the number gets higher, and then more towards green as it gets lower?
    (PS: sorry for my stupidity, these expressions baffle me!)
  • Dan Ebberts
    January 27, 2015 at 2:18 am
    The hue effect doesn’t take expressions, but you should be able to simulate it if you set the Fill color to red and replace the previous expression with this one:
    hsl1 = rgbToHsl([0,1,0,1]);
    hsl2 = rgbToHsl([1,.5,0,1]);
    hsl3 = rgbToHsl([1,0,0,1]);
    if (val < 121)
    h = linear (val,90,121,hsl1[0],hsl2[0])
    else if (val < 151)
    h = linear(val,121,151,hsl2[0],hsl3[0])
    else
    h = hsl3[0];
    hslToRgb([h,hsl1[1],hsl1[2],1])
    Dan
