Activity Forums Maxon Cinema 4D Using splines or objects to rotate another object
  • Using splines or objects to rotate another object
    Posted by Jack Daniels on December 2, 2013 at 1:59 am
    I am making a roller coaster track with 2 bending clones of cynlinders, like this: https://prntscr.com/283zdg
    I want to use 2 tubes (hollowed cylinders) to align to these 2 lines of cylinders, and rotate with it. My problem is getting it to do this. Here’s an example of what I want: https://www.youtube.com/watch?v=FIl206kObB4
    It’d be best if no soft bodies or dynamics were used. Does anyone have a way to do this? Thank you for reading!
    Brian Jones replied 12 years, 8 months ago 2 Members · 3 Replies
  • Brian Jones
    December 3, 2013 at 1:55 am
    that would not be the usual way to do that sort of thing – is there some reason you want to use clones of cylinders?
  • Jack Daniels
    January 7, 2014 at 5:29 pm
    Well with the cloner and a spline wrap, you can make sort of a roller coaster track. I want to know without dynamics how to rotate the camera, with a “align to spline” tag. The cloner with the spline wrap is what the roller coaster is. Thanks for replying!
  • Brian Jones
    January 9, 2014 at 6:38 pm
    the camera has an Align To Spline tag? Just check Tangential there and it should rotate like the spline, if that’s not working for you it helps a lot to use a Rail spline
