Activity Forums Adobe After Effects Expressions Using Source Text to change position
  • Using Source Text to change position
    Posted by Nick Kennedy on March 29, 2023 at 9:43 am
    Hi everyone, I’m trying to create an automated Table for the German Football league. I’m using google sheets to “scrape the Data” and the exporting a .csv file for After effects. This is all working well. My Problem is that I have the Team emblems on the left side of the team name and I would like to change the position of the emblem (Badges) depending on where the Team is. The Team names are empty text layers with an expression pulling the Team names from the CSV File. The Team emblems(Badges) are png Files. Is it possible for an expression to search through a source text(controlled by an expression) and on finding the right content move the emblem to the correct position? I’m kind of lost on this one, so any help would be much appreciated, Great big thanks in advance, cheers, nick
    Nick Kennedy replied 3 years, 5 months ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    March 29, 2023 at 1:08 pm
    Hey Nick, there can be many ways approaching this.
    One of which – creating a single-frame length images composition and timeremapping specific frame based on team name.
  • Nick Kennedy
    March 30, 2023 at 8:50 am
    Hi Tomas, thanks for answering. I think that’s a good suggestion, I have actually OMG been able to solve this myself using the following If / else …/else…./else…. kind of expression. Like if the name at position 1 is team A (is the same as Badge A) then use Position 1 Here is the expression I used for all 18 Teams in the Bundesliga
    x = transform.position[0];
    y = transform.position[1];
    a = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 0”);
    b = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 1”);
    c = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 2”);
    d = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 3”);
    e = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 4”);
    f = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 5”);
    g = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 6”);
    h = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 7”);
    i = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 8”);
    j = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 9”);
    k = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 10”);
    l = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 11”);
    m = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 12”);
    n = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 13”);
    o = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 14”);
    p = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 15”);
    q = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 16”);
    r = thisComp.layer(“Bundesliga 22_23 – Sheet1.csv”)(“Data”)(“Outline”)(“Manschaft”)(“Manschaft 17”);
    if (a==thisLayer.name) [x,y];
    else if (b==thisLayer.name) [x, y+thisComp.layer(“Controll”).effect(“Slider Control”)(1)];
    else if (c==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*2)];
    else if (d==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*3)];
    else if (e==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*4)];
    else if (f==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*5)];
    else if (g==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*6)];
    else if (h==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*7)];
    else if (i==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*8)];
    else if (j==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*9)];
    else if (k==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*10)];
    else if (l==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*11)];
    else if (m==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*12)];
    else if (n==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*13)];
    else if (o==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*14)];
    else if (p==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*15)];
    else if (q==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*16)];
    else if (r==thisLayer.name) [x, y+(thisComp.layer(“Controll”).effect(“Slider Control”)(1)*17)];
    A bit long perhaps but it works well
