Activity › Forums › Adobe After Effects Expressions › Using Sound Keys, need to effect scale within a range.
  • Using Sound Keys, need to effect scale within a range.
    Posted by Indietodd on July 19, 2007 at 4:30 pm
    I’m using the Trapcode plugin “Sound Keys” to make an object scale up and down. I need to do this within a range (92-110).
    The expression I get when I pickwhip to Sound Keys is:
    temp = thisComp.layer(“sound keys”).effect(“Sound Keys”)(“Output 1”);
    [temp, temp]
    Can anyone help me out?
    Thanks in advance!!
    Indietodd replied 19 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 19, 2007 at 5:11 pm
    You can scale the output min and max by selecting “Custom” for the Range Output Min/Max setting. Does that not do what you need?
    Dan
  • Indietodd
    July 19, 2007 at 5:52 pm
    That worked. I didn’t even even see that section of the plugin controls. For some reason I assumed I would have to control that aspect of it through the expression code. But anyway, thanks a ton!!!
    -todd
