Activity › Forums › Apple Final Cut Pro Legacy › Using Qmaster and Compressor
  • Using Qmaster and Compressor
    Posted by Keith Golinski on November 10, 2006 at 3:26 pm
    Just a quick question here. In setting up a little render farm for compressor using Qmaster, do you need seperate serial numbers per machine on the network in order to render? I have the problem of running FCP on two machines on the same network with the same serial code and wonder if it’s worth buying more serial numbers from apple. Your allowed 5 machines per serail number from what they told me.
    Kevin Monahan replied 19 years, 10 months ago 2 Members · 1 Reply
