Activity Forums Maxon Cinema 4D using proxies for soft body simulations
  • using proxies for soft body simulations
    Posted by Fernando Huezo on March 30, 2018 at 6:07 pm
    Hi to all!
    I am find a way to optimize the softbody simulation with a lot of objects in a cloner
    Its possible create a simulation with a low poly objects, bake and after replace them for the high res mesh like Maya or Houdini?
    I tried with a instance refering to the low poly mesh and sim, after bake I replace the reference for the high mesh but lost the softbody deformation
    I share my scene
    12304_softbodyproxyc4d.c4d.zip
    Help please!
    Fernando Huezo replied 8 years, 5 months ago 2 Members · 5 Replies
  • Brian Jones
    March 31, 2018 at 5:03 pm
    yes it’s possible but I’m out of time for the moment. You can use a Mesh Deformer but the order of the steps is very important. I’ll post later when I’m back.
  • Brian Jones
    March 31, 2018 at 10:15 pm
    Not sure if this is the right version of the file or not (or if there’s a better way) as I’m doing this off the phone and I domt remember if it’s saved at home or not…
    If it’s working— in this example I used spheres as the deformation is easier to see. It uses a Mesh deformer to use the proxies shape and is a child of the proxy in the cloner to follow it. The order of putting it together is very important though
    – both proxy and high need to be editable (the Mesh deformer needs that)
    – the proxy has to be a bit bigger to contain the volume (at least in my testing) – a problem in the example since it’s a sphere and simpler, a bit more detail in the proxy would help but it will be dead easy for cubes I would think
    – drop the proxy into the deformer’s Cages slot do not initialize yet
    – cache the dynamics
    – initialize the Mesh deformer
    – fix the visibility (the deformer adds tags)
    12306_softbodyproxyc4d.c4d.zip
  • Fernando Huezo
    April 1, 2018 at 10:51 pm
    Hello Brian Jones!
    First that all thank you very much this really works very well!
    the method is a bit complicated compared to the workflow of Houdini or Maya, I think it might be possible using xRef or intance to be more procedural, I’m not sure but I’ll try and tell you later
    again thank you very much!!!! +100
  • Brian Jones
    April 1, 2018 at 10:52 pm
    as I said it might not be the best way, hopefully there’s a better one
  • Fernando Huezo
    April 1, 2018 at 11:10 pm
    I just tried but it failed haha ????
    So I´ll keep using your method
    thanks!!!
