Activity Forums Adobe After Effects Using ProRes4444 when I don’t need an alpha channel
  • Using ProRes4444 when I don’t need an alpha channel
    Posted by Seth Marshall on April 11, 2013 at 1:51 pm
    I would like to keep high fidelity in my image sequences from Canon 5DmkII raw files. ProRes4444 with 4:4:4 would retain the most color data but I never use transparency and wouldn’t need an alpha channel.
    I do not know how ProRes compresses, but if my alpha channel doesn’t change would the file size be as if it was only saving RGB data and not alpha channel? Or would my files be bloated with data from an unchanging alpha channel?
    I am needing a codec for archival. Otherwise I could use ProResHQ but its only 4:2:2.
    Seth Marshall replied 13 years, 5 months ago 2 Members · 4 Replies
  • Walter Soyka
    April 11, 2013 at 3:20 pm
    [Seth Marshall] “I do not know how ProRes compresses, but if my alpha channel doesn’t change would the file size be as if it was only saving RGB data and not alpha channel? Or would my files be bloated with data from an unchanging alpha channel?”
    I have read elsewhere that the ProRes 4444 alpha channel uses lossless compression. A movie with full alpha shouldn’t be wasting much space on the fourth channel.
    Walter Soyka
  • Seth Marshall
    April 11, 2013 at 4:32 pm
    Thanks Walter! I guess if there’s any compression, even if lossless, hopefully the algorithm would take into account situations where the alpha isn’t needed and compress that channel entirely (like a losslessly compressed audio file for an empty sound track).
    Otherwise if it’s tied into the RGB channels it may eat up bandwidth. But I’m not an engineer, just overly concerned about file size.
  • Seth Marshall
    April 11, 2013 at 4:35 pm
    Thanks Dave. I do like the 4:4:4 option but don’t need an alpha. As long as the compression does the alpha independently then using 4444 won’t be so bad.
  • Seth Marshall
    April 11, 2013 at 6:31 pm
    Hi Dave, copy that for video from DSLR. But actually my files are raw stills (time lapse image sequences). I was the guy you helped yesterday with my mask issue. Thanks though 🙂
    I just wanted to know the best codec for archiving the raw file image sequence before processing and after (so I can have an original and delivery both at highest fidelity).
    I figure 4444 gains me 4:4:4 but depending on how the compression algorithm I’ll either waste bandwidth on an unnecessary Alpha channel or ideally the Alpha channel will recognize there is no transparency information and dedicate bandwidth for RGB or give me a smaller file.
