Activity › Forums › Adobe Premiere Pro › Using Premiere Pro to output a 784 x 2416 30fps H.264 File
  • Using Premiere Pro to output a 784 x 2416 30fps H.264 File
    Posted by Steve Day on June 3, 2013 at 11:25 am
    Hello all,
    I’ve created a timeline editing with native RED 4.5K footage at 784 x 2416 30fps.
    All fine. Business as usual.
    But, when it comes to outputting a H.264, 30fps, 9 mbs data rate I cannot get the output size larger then 784 x 1208.
    (This is a vertical external billboard)
    Any ideas why this can’t be outputted at the sequence settings required?
    Any nuggets of info appreciated!!
    Steve
    Tero Ahlfors replied 13 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Tero Ahlfors
    June 3, 2013 at 11:33 am
    https://en.wikipedia.org/wiki/H264#Levels
    The vertical resolution can’t be more than 2304 pixels with the 5.1 encoding level.
  • Steve Day
    June 3, 2013 at 1:35 pm
    Hi Tero,
    Thanks for the reply and Wiki link.
    Do you know anyway round this to get the resolution requested?
    Steve
  • Tero Ahlfors
    June 3, 2013 at 2:45 pm
    If you need to use H264 those are the restrictions you have to deal with.
  • Steve Day
    June 3, 2013 at 2:53 pm
    Thanks again Tero!
    What would you recommend as an codec alternative?
    Cheers,
    Steve
  • Tero Ahlfors
    June 3, 2013 at 5:00 pm
    You should ask the customer what kind of files the billboard software can play.
  • Steve Day
    June 3, 2013 at 5:16 pm
    Thanks Tero.
    – I’ve asked them just wanted to offer them alternatives..
    Thanks again for your help.
    steve
  • Tero Ahlfors
    June 4, 2013 at 4:01 am
    It’s useless to offer alternatives that won’t work in their system.
