Activity Forums Adobe Premiere Pro Using ‘Palette Gear’ inside Premiere
  • Using ‘Palette Gear’ inside Premiere
    Posted by Brent Ashdown on July 20, 2019 at 3:23 pm
    I want to purchase the Palette Gear Expert set, to use when I grade in Premiere, but there is a question i haven’t found the answer to.
    If i have a slider assigned in Premiere, to alter for example – exposure. And the slider is centred. If i adjust a shot to – 60 on the slider, what happens when i move on to my next shot? Does the slider automatically put the control arm back in the centre, or does the new shot take on the new parameters of the current slider position? Or does it assume i am at 0 and therefore my slider is in the incorrect position? If anyone has had any experience with this kit, let me know your thoughts.
    Best wishes
    Brent Ashdown
    Brent Ashdown replied 7 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
