Activity Forums Adobe Premiere Pro Using PAL MPEG-2 in NTSC Project
  • Using PAL MPEG-2 in NTSC Project
    Posted by Drew Angle on July 11, 2016 at 10:17 pm
    Hey!
    I’m editing a documentary in Premiere. I acquired some files from one of the subjects. They seem to be DVD rips that are PAL.
    Specs:
    MPEG-2 Video, AC3, 48000Hz
    The file plays fine in QT and VLC. When I try and convert this file to anything else the audio is always out of sync.
    Suggestions?
    Drew Angle replied 10 years, 2 months ago 2 Members · 4 Replies
  • Ann Bens
    July 11, 2016 at 10:45 pm
    Ask for the original disk.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Drew Angle
    July 12, 2016 at 4:53 pm
    I can look into this. What would be the benefit of having the original PAL-DVD over the file I currently have?
  • Drew Angle
    July 12, 2016 at 4:55 pm
    Great – thank you, yes this is very helpful! Makes a lot of sense.
    Why is it better to go towards 29.97fps over an NTSC 24 (or 23.97)?
  • Drew Angle
    July 12, 2016 at 5:17 pm
    So here’s one fix that seemed to be working and I’m curious what the thoughts on this approach are:
    In Adobe Premiere I select the PAL clip in its bin, right click and choose to “Interpret Footage” – I then change the frame rate from 25.000 to 23.976 (the base frame rate for my project).
    If I drag this clip to the timeline and advance the audio by 12 frames it seems to play in sync.
