Activity Forums Adobe After Effects Using objects/compositions to spell a word without masking
  • Using objects/compositions to spell a word without masking
    Posted by Joey Campbell on August 12, 2013 at 5:14 pm
    Hi – I’m just wondering if its possible to do the technique at 1.30-1.32 in the following link using particular:
    https://vimeo.com/25118844
    If so is there any where you can type in the word you want the particles to spell or do you have to use a stencil alpha mask?
    There is a similar style here at 31sec:
    https://vimeo.com/51265319
    where code is used to spell out sections of each letter….does this have to be done using masks (surely there is a quicker way!)
    Out of curiosity at 30secs in the same clip the word virus is made up of hash characters….is a plugin required for this ?
    Joey
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Joey Campbell replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
