Activity Forums Adobe After Effects Using Newton 2 to create vibrations based on audio?
  • Using Newton 2 to create vibrations based on audio?
    Posted by Mike Imam on August 18, 2014 at 7:21 pm
    Hi there,
    Anyone know of a way to use Newton 2 to create an effect of a wire or string vibrating, kind of like a guitar string, based on real audio? I’d actually like to have a few items bounce on the wire, according to the oscillations.
    I used the tutorial here to get my wire vibrating:
    https://www.youtube.com/watch?v=2MVbb2W_rBY
    It uses expressions and bezier warp tool on a shape. Thing is, when I open Newton, the vibration animation is not taken into account, so when I have an object fall onto the line, Newton treats the line as static (since the script only kicks in on the main AE timeline).
    So is there:
    A) A way to create physics in Newton based on audio levels, or
    B) Is there alternately a way to get Newton to recognize that my shape is being warped on my main timeline, and to have the objects touching it react appropriately?
    Mike Imam replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
