Activity Forums VEGAS Pro Using multiple frame rates
  • Using multiple frame rates
    Posted by Ashley Kay on January 9, 2012 at 10:02 pm
    I am putting together a video that has 29.97 fps and it will contain different video clips. I have different frame rates. Some are 23.97 fps. and some are 29.97 fps. What do I do to prevent the rendered video from being so jerky due to different frame rates?
    John Rofrano replied 14 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    January 11, 2012 at 12:43 am
    [Ashley Kay] “What do I do to prevent the rendered video from being so jerky due to different frame rates?”
    It should’t be jerky. If you render everything at 29.97 Vegas will add the extra frames required to bring the 24p up to 29.97. It should be smooth unless you disabled resample for some reason.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
