Activity › Forums › Adobe Audition › Using multi-channel files
  • Using multi-channel files
    Posted by Geoff Bailey on December 1, 2012 at 10:41 pm
    I’m just making the switch over to Audition and can’t find the following in the help.
    I do a lot of film work so I get multi-channel WAV files from production. When I drag them into a track, they show up as 6-channel files. How do I choose which channel to use?
    I see that in the File Window I can extract mono files from the multi-channel wav, but that creates 6 separate files. With thousands of WAV files that just makes my project window even messier.
    Is there a way to select in the multi-track editor window which channel to use? And even better, is there a way I can switch back and forth (say I start the mix with the boom on channel 1 and then later decide to switch to the lav on channel 3)?
    Thanks.
    Geoff Bailey
    Creative Director
    Loyalkaspar
    http://www.loyalkaspar.com
    Christopher O’brien replied 13 years ago 3 Members · 3 Replies
  • Joseph W. bourke
    December 13, 2012 at 7:35 pm
    Hi Geoff –
    Sorry this response took so long – according to Adobe, Audition will handle multi-channel files:
    https://blogs.adobe.com/audition/2011/04/surround-yourself-natively-with-5-1-multichannel-editing-and-mixing.html
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Geoff Bailey
    December 13, 2012 at 7:52 pm
    Thanks for getting back to me, Joseph, but unfortunately that post doesn’t address my problem. The 6-channel audio files aren’t 5.1 files. They are standard six-channel WAV files where boom is on 1, mix is on 5 and 6 and 2-4 are various wireless lav mics.
    The problem is that when I drag them into a track all 6 channels play down. Obviously this doesn’t work. I want to be able to have (let’s say) only ch. 1 (boom) play.
    As I said, I know I can extract mono files in the project window, but that creates 6 times the number of files in the project window. I’m hoping there is a more elegant way to do it.
    In Soundtrack Pro, for instance, if you hold option when you drag them into a track, the 6-channels will come in as mono on six different tracks. I can select the one I want. And if I want to change it later, I just right click on it and switch the channel that is playing back.
    Geoff Bailey
    Creative Director
    Loyalkaspar
  • Christopher O’brien
    September 29, 2013 at 10:40 pm
    Im having the exact same problem. Did you ever find a solution to this?
