Activity Forums Boris FX Particle Illusion using motion blur turns exports B&W
  • using motion blur turns exports B&W
    Posted by Gurudude on June 21, 2005 at 8:49 pm
    Hey guys, I need a bit of help.
    I’m trying to export an effect with a transparent background. The problem is, whenever I use motion blur and “Save Alpa” the .png’s turn black & white. What am I doing wrong?
    Gurudude replied 21 years, 2 months ago 2 Members · 2 Replies
  • Alan Lorence
    June 21, 2005 at 9:27 pm
    Are you using regular motion blur or high-quality? If HQ, try regular. Also, are you generating fields?
    Finally, are you running with software rendering or with hardware acceleration? You could try switching to software rendering, or try using pIllusionRender instead.
    Alan.
    wondertouch
  • Gurudude
    June 21, 2005 at 10:35 pm
    Using software rendering helped, but the path carved out by the motion blurred effect still has a solid background. I hope that made sense.
    If not, take a look at this:
    https://img275.echo.cx/img275/9150/100235id.png
    See how everything outside the path of the particles is transparent?
