Activity › Forums › Avid Media Composer › Using lots of mixed aspect ratios in an SD project
  • Using lots of mixed aspect ratios in an SD project
    Posted by John Kroil on May 29, 2013 at 8:53 am
    Hey folks,
    I am working on a project which is made up of montage of youtube videos, taken at various qualities, some full SD, some less than full SD, some 720p some 1080p, and I want to import all of these videos into my project keeping their original aspect ratios (I would eventually crop for the HD, and zoom in for the small files). Is there a way to do this with “one fell swoop”? so that I can import the (hundreds) of various videos in various aspect ratios without organizing them all first by aspect ratio and converting them?
    John Pale replied 13 years, 4 months ago 3 Members · 2 Replies
  • Fred Jean
    May 29, 2013 at 11:48 am
    So I guess you are going to a 4:3 sd project?
    There will be cropped involved anyway and you are not only mixing different aspect ratio but also different
    Resolutions. And what about
    Framerates?
    You are going to have a drastic lost in resolution if you zoom-in, unless you
    Establish your Project to sd, wich is your plan
    If I understand well, and reduce
    Your hd material.
    If you do the opposite, you’d have to degrade on purpose your hd footage so there is no visual jump between the different sources.
    Probably the best bet is that you
    Lock your project to your sd specs,
    Then create a 720p project with all
    The hd material included The 1080
    In the case they all match framerate
    Otherwise you’d have to create
    A 720 project for each,
    and bring the bin, Or bins
    Into the sd project, then crop your
    Hd clip saving the effect into a bin
    So you can reuse-bring the effect on each hd
    Segment you used.
    Lots of little manips but it will
    Work fine.
    Fred.
  • John Pale
    May 29, 2013 at 12:39 pm
    I wouldn’t do it in one fell swoop.
    I’d separate the source material by its original format. Capture or AMA/Transcode into projects that match the original formats. Then move the bins into the main project.
    Let Avid Mix and Match do the conversion on the fly in your main project. You’ll have the option of how to handle the aspect ratios, if you make the Reformat column visible in the bin (its not visible by default)). You can set lots of clips to letterbox or center cut AAF once with a pull down menu.
